derosbys's avatar
Sep 24, 2018
My Firmware is V1.0.2.52 - From the Firmware update it says there is no update avalible
I saw on the netgear site that there is a new firmware update V1.0.2.58 so I went to the advanced settings and told it to check for a firmware update but is says there are not firmware updates avaibl...
  • microchip8's avatar
    Sep 24, 2018
    There's an issue on NG's side that doesn't report the new version. You can always manually download and update. Don't worry, your router supports it or else NG won't publish it
    That said, be aware that multiple users have reported wifi issues on firmware .58 and some have rolled back to .52
