Finchy70
Aug 02, 2018Aspirant
My home server url wont connect when connecting on home network
I have recently moved from an ASUS AC66U to a Nighthawk X4S.
I have a server on my network with the url https://myserver.com for example. If I try to connect from home with the url it wont con...
- Aug 03, 2018
Hi. All fixed now. Updated to latest firmware and now nat loopback works.
BIG_DOG
Aug 02, 2018Luminary
setup and use a DDNS service. That way you will get a dedicated address that will never change whatever router you use! Hope this helps!
