Hoopoat
Jan 27, 2020Aspirant
My HP Envy 15t can't connect wirelessly with my Nighthawk R8000
My HP Envy 15t isn't connecting wirelessly with my Nighthawk R8000. I started with HP and have tested my WIFI card adapter (it works) and I've done everything HP threw at me including backing up my l...
- Jan 29, 2020
This tells us that the problem is limited to the wifi bit of your HP. So, not really that weird, and not much, if anything, to do with your wifi Netgear device.
Does the HP work on other wifi?
One guess is that you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
Again, nothing to do with the R8000.
michaelkenward
Jan 28, 2020Guru - Experienced User
Bit hard to unravel what is going on in there. Are you having problems getting a laptop to connect to the wifi?
Hoopoat wrote:
It still gives me the following message "No internet, secured".
Where do you see this message? What are you doing when it appears?
Can other things connect to the wifi?
Hoopoat
Jan 29, 2020Aspirant
michaelkenward If I disconnect the ethernet cable and try to connect to the WIFI router, it says connected but "No internet, secured". I also have to hit the disconnect button. Everything else connected to the router is fine and not having issues. TV, tablets, phones, game system, guest's phones, printer etc. The HP Envy 15t can connect through a hotspot. It's a weird one.
