BrainierGecko3
Nov 14, 2020Aspirant
My internet connection is 300 mbps but my router is doing 49 now?
I thought it was the modem, but speed test shows that without the router, I'm getting between 317 and 343 mbps. With the router, it was 80. Then I unplugged the router and got the solid orange globe....
antinode
Nov 14, 2020Guru
> Model: R6080|AC1000 Dual Band WiFi Router
Firmware version? Connected to what?
> [...] without the router, I'm getting between 317 and 343 mbps. With
> the router, it was 80. [...]
If you have an R6080, then speeds over 100Mb/s would be astounding.
https://community.netgear.com/t5/x/x/m-p/1711958
> [...] What is going on?
I don't know. Perhaps you should stop trying to invent new
settings-reset methods in attempts to remove a hardware limitation.
