BrainierGecko3
Nov 14, 2020Aspirant
My internet connection is 300 mbps but my router is doing 49 now?
I thought it was the modem, but speed test shows that without the router, I'm getting between 317 and 343 mbps. With the router, it was 80. Then I unplugged the router and got the solid orange globe....
antinode
Nov 14, 2020Guru
> Model: R6080|AC1000 Dual Band WiFi Router
Firmware version? Connected to what?
> [...] without the router, I'm getting between 317 and 343 mbps. With
> the router, it was 80. [...]
If you have an R6080, then speeds over 100Mb/s would be astounding.
https://community.netgear.com/t5/x/x/m-p/1711958
> [...] What is going on?
I don't know. Perhaps you should stop trying to invent new
settings-reset methods in attempts to remove a hardware limitation.
BrainierGecko3
Didn't invent it. I found it as a possible solution. I was getting over 300 mbps just 48 hours ago.
- antinodeNov 14, 2020Guru
> [...] I was getting over 300 mbps just 48 hours ago.
Through an R6080? I don't see how. (Note: "m" = "milli" = 1/1000.
"M" = "mega" = 1000000.) - michaelkenwardNov 15, 2020Guru - Experienced User
Measured how? You may be able to measure 300 Mbps on a local wifi connection, but not out to the Internet.
According to the Data Sheet, the LAN ports in the R6080 are "Fast Ethernet" and can't go faster than 100 Mbps.
The R6080 is a bottom of the range router, even so it is amazing that Netgear produced a device that slow in 2017. If your Internet speed is faster than 100 Mbps, your only option is to replace the router.
