Pissedjedi
Mar 22, 2020Initiate
My internet speeds cut from nearly half a gig to a fraction of the speed.
Currently my internet provider is Charter spectrum. I have a 350 meg internet plan. With my brand new motorala Modem MOTOROLA 16x4 Cable Modem, White Model MB7420, 686 Mbps DOCSIS 3.0 . I am getti...
- Mar 22, 2020
What firmware is on the R8000?
was the R8000 a new device? or prior setup?
I'd start by factory resetting and re-installing manually. many times prior qos/traffic monitoring settings can cause issues.
Mar 22, 2020Guru - Experienced User
Pissedjedi
Thank you so much. Sometimes the simplest solutions fix everything. I did the reset. Had the nighthawk recheck the internet settings. rebooted my pc. and now I am getting 480 megs direct from the nighthawk. A new record. Thanks so much!
