cjbutterfly
Dec 07, 2020Guide
my iphone can only get 22mb on wifi instead of the 210mb it is meant to have
hi guys , firstly I am a tech noob ish , i have the xr500 router set up at home as my kds are gamers and the virgin hub was poop! every device in my house get speeds of 210 mb but my ihone will only...
cjbutterfly
Dec 07, 2020Guide
yes all other devices work perfectly , how do i check which i am connected to sorry
Dec 07, 2020Guru - Experienced User
I hate to say this but
1. I don't have an iphone so I'm not sure if you can check it through the wireless settings (android guy)
and
2. I dont' have a xr500 (or any other dumaOS device) so i have no idea if the attached devices page shows what band you're connected to.
Sorry!
maybe Netduma-Fraser has a little more info on the XR500 side of things :)
- cjbutterflyDec 07, 2020Guide
dont worry i am starting to wish i was an android girl lol, i am trying to find out on the dashboard but it keeps saying r hasnt loaded yet :(
god i have another problem now the dashboard wont even load just keeps saying the r app hasnt loaded try again in a minute :(
- plemansDec 07, 2020Guru - Experienced User
What version of the firmware are you on?
Have you tried a simple reboot of the router?
