radio_chas
Feb 12, 2018Follower
My laptop computer does not have an ethernet port.
My laptop has no ethernet port. Can I connect to the router via the USB 2.0 port to upgrade the firmware, although it is marked printer on the router? What other options do I have?
- Feb 13, 2018
> [...] download the new firmware to a USB stick and flash from that.
Please explain what that means. How does using a USB storage gizmo
help matters?
> Just follow the Release Notes.
I don't see anything there about a USB storage gizmo. All I see is
"[...] download and extract the new firmware to a convenient place such
as your desktop."
> You can upgrade firmware over wifi.
Firmware upgrade instructions:
Note: To avoid disconnect issues during the firmware download
process, NETGEAR recommends the firmware update be performed on a
computer with wired connection.
michaelkenward
Feb 13, 2018Guru - Experienced User
No.
You can upgrade firmware over wifi. If that worries you, then download the new firmware to a USB stick and flash from that.
R6700v2 Firmware Version 1.2.0.16 | Answer | NETGEAR Support
- antinodeFeb 13, 2018Guru
help matters?
as your desktop."
