radio_chas's avatar
radio_chas
Follower
Feb 12, 2018
My laptop computer does not have an ethernet port.
My laptop has no ethernet port.  Can I connect to the router via the USB 2.0 port to upgrade the firmware, although it is marked printer on the router? What other options do I have?
  • antinode's avatar
    antinode
    Feb 13, 2018
    > [...] download the new firmware to a USB stick and flash from that.
       Please explain what that means.  How does using a USB storage gizmo
    help matters?
    > Just follow the Release Notes.
       I don't see anything there about a USB storage gizmo.  All I see is
    "[...] download and extract the new firmware to a convenient place such
    as your desktop."
    > You can upgrade firmware over wifi.
          Firmware upgrade instructions:
          Note: To avoid disconnect issues during the firmware download
          process, NETGEAR recommends the firmware update be performed on a
          computer with wired connection.
