Blessings2all
May 20, 2019Tutor
My modem and/or router are blocking my websites
I have a CM400 High Speed Cable Modem and an AC1200 (R6220) Smart WiFi router and they are blocking me from my own websites that I access on a daily basis. I know that the sites themselves are workin...
- May 20, 2019https://www.netgear.com/support/product/R6220.aspx#download
The release notes walk you through the install
May 20, 2019Guru - Experienced User
If you hook directly to the modem, do the sites work?
I know you said you checked for updates on the firmware. The automated check doesn't always work. What firmware are you running on it?
Are you using a certain dns provider or the automatic one?
Blessings2all
May 20, 2019Tutor
Router Firmware Version
V1.1.0.34_1.0.1
