Blessings2all
May 20, 2019Tutor
My modem and/or router are blocking my websites
I have a CM400 High Speed Cable Modem and an AC1200 (R6220) Smart WiFi router and they are blocking me from my own websites that I access on a daily basis. I know that the sites themselves are workin...
- May 20, 2019https://www.netgear.com/support/product/R6220.aspx#download
The release notes walk you through the install
May 20, 2019Guru - Experienced User
1.1.0.86 is the current firmware. I'd install that manually, factory reset the device, and try without restoring and configuration data. Make sure to install it over a hardwired connection.
Blessings2all
May 20, 2019Tutor
How do I install it manually and where is the file?
