Raflus
Jul 09, 2022Aspirant
My Netgear R7000 won't start after power outage
I had power issue with my router couple of times do not know why and what was cause. Today I had power outage and router would not switched back on after the restored power. I resolved this by pullin...
Jul 09, 2022Guru - Experienced User
Did it restart after unplugging and replugging? It might have been rebooting and gotten interrupted during bootup with another power surge/failure and got it "stuck".
I've seen that happen. Usually killing power or a factory reset fixes it unless something was corrupted.
Raflus
Hi
Thanks for the reply. Yeah after unplugging and plugging in again has restarted. I recall I was doing something with the fuse and it might cause the problem. I will double-check it. Thanks for pointing me in the right direction.
