blkcffee's avatar
blkcffee
My new AC2600 won't connect to the internet, but my old Linksys will.
Title. Everything else will connect, but I can't seem to get a connection through to the internet. Help! I've already tryed power cycling and resetting the router.
  • Additional information is required before this can be sorted out.
    What is the brand name and model number of the modem/gateway you are connecting your router to?
    Are the devices you are connecting to the router going through an ethernet cable or wi-fi or both?
    What are these devices?
    • blkcffee's avatar
      blkcffee
      Alright- I'm going to have one device running through an Ethernet cable and about 5 on wireless. Not sure about this model of the modem but here's some pics.
  • plemans's avatar
    Kitsap is correct. Details are needed and key.
    Especially what modem/gateway you're connected to.
    Some routers play nicer with double nats than netgear devices do.
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes if you're in a double nat? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
