Pshell
Sep 30, 2021Aspirant
my new Netgear AC1600 Wifi Router R6330 doesn't show its 5.0 GHZ, only its 2.4 GHZ
my internet company helped me hook up my Netgear Wifi Routher 2.4 - 5ghz but only 2.4 ghz is showing - it should show 5 ghz as well. Does anyone know why it isn't showing the 5 ghz?
Sep 30, 2021Guru - Experienced User
is the 5ghz wifi light on?
Have you logged into the router to see if whoever set it up, setup a different ssid for the 5ghz?
