Ultra4life
Jan 31, 2021Aspirant
My password doesn’t work for router model C3700
My password no longer works
Jan 31, 2021Guru - Experienced User
wifi password?
password to log into the router?
Password for the app?
which password?
you can always go to the support site that has manuals, guides, troubleshooting
https://www.netgear.com/support/product/C3700.aspx
or even just try resetting it back to factory to get back to defaults (and reinstall)
simply push and hold reset for 7-15 seconds while its powered on.
default login: admin
default password: password
Ultra4life
Password for the router. My smart TV is not connected to the internet and my netgear pw doesn’t work.
- michaelkenwardFeb 01, 2021Guru - Experienced User
Ultra4life wrote:
....my netgear pw doesn’t work.What are you doing that showed that and what messages do you see?
Ultra4life wrote:
My smart TV is not connected to the internet ....What has that got to do with your router's password?
Connecting a TV to the network is usually best done through the TV's controls and set up routine. The router rarely does much more than spit out the wifi signal. It is then down to the TV to do its thing.
Where possible, it is usually easier to use a wired connection from the router to the TV. It is easier to set up and less likely to fall over. If you can't run Ethernet cables around the place, you could look into Powerline Ethernet. It turns your mains wiring into an Ethernet circuit.
