lalascott7's avatar
lalascott7
My R6230 — AC1200 Smart WiFi Router doesn't show internet button after connected new modem
I just set up my modem and got it activated through my ISP. Now when I hook up my router (plugging 1st ethernet cable into back of modem and other into back of router that says "internet", then the 2...
  • lalascott7's avatar
    lalascott7
    Oct 08, 2020
    Hey you know what, I fixed it. All I had to do was reset the router since it was set up properly. I was also about to go to routerlogin.net and go through the genie setup process again, plus do a firmware update. Next thing I know, it was working and I was able to get the app to detect is as well so I'm good. Thanks for reaching out. Too bad there's no chat support available for customers like me.
