BlueWonder
Dec 19, 2017Aspirant
My R7000 bricked during update to V1.0.9.18_1.2.27
During upgrading my router something went wrong. Now I can not connect to my router. Even trying to reset or reflash with tftp will not work. What to do?????
- Dec 20, 2017
A friend had the solution.
I used TFTP2.EXE on my laptop (Windows 10).
He told me to uninstall TFTP2.EXE and activate TFTP on my windows 10 laptop.
After that i run CMD and type TFTP -i 192.168.1.1 PUT R7000-V1.0.9.18_1.2.27.chk
This is for me the solution. My R7000 is working again.
William10a
Dec 19, 2017Master
If your willing to open the router up you reflash the router with the use of a serial cable there are many videos on the web that show how to this may be your only chance to sve the router if you can not access routervia a lan port. I would clear the nvram before you refash the router there still may old data in it causing poroblems.
- BlueWonderDec 20, 2017Aspirant
