BlueWonder's avatar
BlueWonder
My R7000 bricked during update to V1.0.9.18_1.2.27
During upgrading my router something went wrong. Now I can not connect to my router. Even trying to reset or reflash with tftp will not work. What to do?????
  • BlueWonder's avatar
    BlueWonder
    Dec 20, 2017
    A friend had the solution.
    I used TFTP2.EXE on my laptop (Windows 10).
    He told me to uninstall TFTP2.EXE and activate  TFTP on my windows 10 laptop.
    After that i run CMD and type TFTP -i 192.168.1.1 PUT R7000-V1.0.9.18_1.2.27.chk
    This is for me the solution. My R7000 is working again.
