mirvingm
May 12, 2018Aspirant
My R7000 toggles between "looking for Networks" and on
My router does not want to stay connected to the internet? It jumps back and fourth between Looking for Networks and on constantly? If I restart my IMac it seems to solve the problem temporarily? But...
- Oct 23, 2018
I fixed my router within 1 hour after months of troubles!
It's called a TP-Link router.
Replace the router with a different brand and no more troubles!!
myersw
Nov 21, 2018Master
Amazing how many folks fix their Netgear router issues by getting something different from another manufacturer. I did the samething after a very disappointing experience with a r8000 and r8000p with constant and not fixed firmware issues. They used to be my go to and on my recommended list. Not anymore.
michaelkenward
Nov 21, 2018Guru - Experienced User
Sigh.
- myerswNov 21, 2018Master
Sigh all you want. Right now Netgear is putting out crap firmware and, unfortunately has been. I guess you will figure that out someday. A r8000 and r8000p convinced me they did not have a clue after multiple updates.
Sell your Netgear stock before they go under, IMHO.
