Savier's avatar
Savier
Tutor
Sep 28, 2021
My router does not allow me to save my DNS servers settings
I'm not sure that I put the rounter name correctly, but if not, my router name is NighthawkAX8AX6000 WiFI Cable Modem
Router, Model CAX80. Since I got the router/modem i wasnt allowed to change my settings on my device. For example, when I try to change the DNS Servers, it doesn't save my settings, if anyone knows why this is please let me know.
Thank you
  • plemans's avatar
    what error are you getting?
    what dns settings are you trying to use?
    Again, what actually happens? Screen snips/better description helps.
    • Savier's avatar
      Savier
      Tutor
      I put 8.8.8.8 as my primary and 8.8.4.4 as my secondary DNS, than I hit apply and the page refreshes like it does when I try to apply something on the site. But nothing saved, the text becomes empty, and I know that I didn't not get any errors because before I put the wrong DNS Server and it gave me a error. I do have some boxes for Internet Setup page that say undefine, I don't know if thats maybe part of it or the reason,
      Thank you.
      • plemans's avatar
        got a screen snip of the errors?
        What firmware is on the router portion?
