Greg_Mouchyn
Mar 17, 2022Aspirant
My router is choking my internet speed
Hello Folks, My router is slowing down my internet speed. I have a 400Mbit/40Mbit setup, and have verified that speed at the modem. But on the router side it is choked down to 160Mbit. ...
Mar 17, 2022Guru - Experienced User
1. what router do you have?
2. what modem/gateway do you have?
3. make sure qos, access control, traffic monitoring, and parental controls are all disabled and reboot the device?
Greg_Mouchyn
Mar 18, 2022Aspirant
I have the R6400v2.
Cable modem DOCSIS 3
None of that is on.
It was working at the specified speed and now doesn't.
I am guessi g when I did the firmware update, that broke it.
Now I can barely get 200Mbit throughput.
None of that is on.
- plemansMar 19, 2022Guru - Experienced User
You might try updating to the latest 1.0.4.126 firmware, then doing a factory reset and reinstall.
https://www.netgear.com/support/product/R6400v2.aspx
