bagjunah
Nov 27, 2021Follower
my router won’t reconnect
powered off then back
michaelkenward
Nov 28, 2021Guru - Experienced User
Is the A7000 WiFi USB Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
wcalifas
Nov 28, 2021Prodigy
do you have cable internet? If so you have to reboot the modem and wait til it connects to your provider then you turn on the router to detect the internet.
