dennisoates
Nov 20, 2020Guide
MY router won't allow Wyze camera R6900p Nighthawk
I have 5 Wyze cameras, 2 wyze outlets, and two Nest Devices all were added with no problem to the router. But now it is refusing to allow me to add another Camera, I get message from Wyze camera, ca...
Nov 20, 2020Guru - Experienced User
They're not.
If you try to activate it through a different device (phone/tablet) on your network, what happens?
Something else to try? Shut down your current router and camers and turn the hotspot on on a phone. Use the same ssid/password as the primary router. Then use a different phone to setup the wyze. Once its setup, power off your hotspot and turn the router back on. maybe it'll auto connect to the router and work.
dennisoates
Nov 20, 2020Guide
Hmmmm, i will try this later today, thanks
