7Karma
Mar 17, 2019Aspirant
my wired speed is alot slower than wireless speed?
hey guys I'm having some trouble with figuring out what is going on.
atm I have service provider with 500 mbps plan. and with router connected to usually 6 devices(1 wired ethernet connected to...
- Mar 17, 2019
Do not use a crossover cable to connect a PC to router. Cat 5e or Cat 6 cables should work fine. Other qestion is, does the PC Ethernet port support 1gig. Older PC may not.
Kemer
Mar 17, 2019Tutor
I would guess that your PC-Router connection is Auto-Negotiating to 100Mbps, rather than the 1000Mbps that you would like. Under Advanced, you may find the ability to find "show statistics", there you could check the negotiated link speed. If my guess is correct, you would see 100M/Full (100Mbps/Full Duplex). As to why it is negotiating to 100Mbps could vary from the PC to the Ethernet cable to the Router. KISS method says put in a new Ethernet Patch cable.
- 7KarmaMar 17, 2019Aspirant
You are right. I checked the 'show statistics' and WAN is at 1000M/full but LAN1 is at 100M/full. there is also WLAN b/g/n at 800M and WLAN a/n/ac at 1733M. Is that something I need to worry about?
I will go ahead and replace both ethernet cables (modem to router, from router to my pc). I noticed that both ethernet cable is cat6?. is there specific cat x cable I should be getting?
EDIT-one of the ethernet cable(the one that goes from my router to my pc) says crossover on the cable but the other one doesn't? is it something I need to check it out as well?
- KemerMar 17, 2019TutorIt seems The WLAN rates that you are seeing are normal, it would be the 2 different frequencies (2.4GHz and 5.8GHz). Cat6 is a more stringent cable standard, which supports more throughput. On the leg that negotiating to 100/Full, you could have a damaged, kinked cable, bad connection, poorly routed, etc or possible that your PC just doesnt support 1000Mbps very well. I would go the direction of swapping out the cable and changing the routing if it is in an electrically noisy area.
- myerswMar 17, 2019Master
ok so I won't use crossover cable from router to PC. how about the cable from modem to the router? I assume I shouldn't use the crossover on both ethernet connection but never hurts to be safe.
I believe my ethernet port is good since it says it uses Intel 1219V so I googled and it says it supports 1gigabit ethernet connection.
I will replace both ethernet cables tomorrow and see if it solves the issue
