7Karma's avatar
7Karma
my wired speed is alot slower than wireless speed?
hey guys I'm having some trouble with figuring out what is going on.   atm I have service provider with 500 mbps plan. and with router connected to usually 6 devices(1 wired ethernet connected to...
  • myersw's avatar
    myersw
    Mar 17, 2019
    Do not use a crossover cable to connect a PC to router. Cat 5e or Cat 6 cables should work fine. Other qestion is, does the PC Ethernet port support 1gig. Older PC may not.
