7Karma
Mar 17, 2019Aspirant
my wired speed is alot slower than wireless speed?
hey guys I'm having some trouble with figuring out what is going on.
atm I have service provider with 500 mbps plan. and with router connected to usually 6 devices(1 wired ethernet connected to...
- Mar 17, 2019
Do not use a crossover cable to connect a PC to router. Cat 5e or Cat 6 cables should work fine. Other qestion is, does the PC Ethernet port support 1gig. Older PC may not.
myersw
Mar 17, 2019Master
7Karma
ok so I won't use crossover cable from router to PC. how about the cable from modem to the router? I assume I shouldn't use the crossover on both ethernet connection but never hurts to be safe.
I believe my ethernet port is good since it says it uses Intel 1219V so I googled and it says it supports 1gigabit ethernet connection.
I will replace both ethernet cables tomorrow and see if it solves the issue
