NikoBarton
Nov 10, 2021Aspirant
Mystery Xboxes
My Nighthawk app shows two devices connected to Wifi that are listed as Xbox Consoles. I don't have an Xbox but I assume these are other devices I have connected that aren't showing such as my wife'...
Nov 10, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Please give router model information as well.
And how your xbox is connected.
Please post a screen capture of what your seeing in the app as well.
Thank you.
NikoBarton
Thanks - I didn't see any other forums when I landed on the page. I'll look there for further info.
- FURRYe38Nov 10, 2021Guru - Experienced User
You might remove the app and re-install it with the xbox turned OFF, leaving the other devices online and see if the app reports something different.
Good Luck.
