denisyv
May 22, 2021Follower
N300 WiFi Range Extender: The extender fails to connect to new WiFi, but shows Old WiFi
Hi, I recently changed broadbands. I had the extender connected to the old wifi (PLUSNET) but it is now obviously no longer in use. I have tried to connect the extender to the new Wifi (XLN For ...
May 22, 2021Guru - Experienced User
What actual extender do you have? (model)
Have you tried factory resetting it and installing it using the installation assistant and NOT wps?
What router are you connecting it to?
