Jno2
Dec 03, 2020Tutor
N600 WNDR3700v3 not connecting with netgear genie app - can't set it up!
I have a Netgear R6400 and easily set it up with the Netgear Genie website (a while back). Now it seems the Genie website has been replaced by a mobile app that has problems... so what to do? I'm tr...
Dec 03, 2020Guru - Experienced User
You can connect to it and install using the browser. You don't have to use the app. I prefer the browser based method .
Easiest way is just hardwire in a pc/laptop to it and go to routerlogin.net or the ip address (default is usually 192.168.1.1)
- Jno2Dec 03, 2020Tutor
I tried connecting with a laptop. Using the IP address it says "This site can't be reached" I tried it with laptop connected to wireless and disconnected.
If I try using routerlogin,net it gives me all kinds of reasons why it won't connect. I also tried a different browser but got the same message.
