frankmc
Mar 12, 2021Aspirant
N6020 as a repeater
I have a N6020 router. Can I make this a extender/repeater? If so, how do I do that. Thank you.
Mar 15, 2021Guru - Experienced User
Seeing as how there isn't a N6020 router, maybe you mean R6020?
And if it is a R6020, then no, it doesn't have a repeater mode.
frankmc
Mar 15, 2021Aspirant
Thank you.
Ypu are right. It is a R6020.
- antinodeMar 15, 2021Guru
> [...] it doesn't have a repeater mode.
But, if you can connect it to your main router using an Ethernet
cable (or equivalent), then an R6020 can be configured as a wireless
access point.Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Use the Router as a WiFi Access Point Only".- frankmcMar 15, 2021Aspirant
Thank you.
