odbammb
Dec 15, 2021Star
Name of Wireless1 SSID Not Showing in Attached Devices SSID Column
SRR60 + 2 SRS60 V2.7.0.122 Every since the V2.7.0.122 firmware upgrade the Wireless-1 router to AP backbone SSID name does not show up in the Attached Devices screen SSID column. Also the overvie...
Dec 15, 2021Guru - Experienced User
Try a factory reset and setup from scratch after the FW update.
Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.
