PaulGorman
Mar 26, 2022Aspirant
NAT D setting for Nintendo Switch
Hi Community. We are having trouble with the NAT D setting on out nintendo switch. We have tried all sorts of IP and DNS numbers, port forwarding and checking of security settings (it allows the swit...
Mar 26, 2022Guru - Experienced User
Advice would be a full understanding of your setup.
1. what modem/gateway do you have?
2. what router are you using?
3. what firmware is on the router?
- PaulGormanMar 26, 2022Aspirant
Apologies. I am not very computer literate. Where do I find all that information? Thanks
- michaelkenwardMar 27, 2022Guru - Experienced User
This will tell you which Netgear device you own.
Then there is this:
Search - NETGEAR Communities – Nintendo Switch
Add your device model for finer details.
