Xboxlivegamer
Feb 09, 2016Aspirant
NAT Issues for Xbox One Live, AC1900 Smart WiFi Router model# R7000
I'm having trouble getting open NAT for my Xbox One, it is set to moderate as of now. I've tried turning NAT filtering to open, address reservation, switching from ethernet to Wireless, port forwardi...
- Feb 11, 2016Yes, that's it. So, your ISP is NATing your traffic. Your situation is similar to the guy with WiMAX. I went and found that thread.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NIghtHawk-R7000-PS4-Nat-Type-Strict-3-Issues/td-p/1026988
That guy had to call his ISP and ended up paying for a public IP address to solve his NAT problems. You'll need to call your ISP and either ask for a public IP address, or ask them how to set up port forwarding through their gateway. Read the other thread.
TheEther
Feb 09, 2016Guru
Is your R7000 sitting behind another router (e.g. your ISP's)?
rpoffen
Feb 10, 2016Virtuoso
It is easy to tell if the R7000 is sitting behind another router, check the IP address assigned to the WAN port of the R7000, if it is in the range of 10.0.0.x or 192.168.x.x then it is behind another router.
