Xboxlivegamer
Feb 09, 2016Aspirant
NAT Issues for Xbox One Live, AC1900 Smart WiFi Router model# R7000
I'm having trouble getting open NAT for my Xbox One, it is set to moderate as of now. I've tried turning NAT filtering to open, address reservation, switching from ethernet to Wireless, port forwardi...
- Feb 11, 2016Yes, that's it. So, your ISP is NATing your traffic. Your situation is similar to the guy with WiMAX. I went and found that thread.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NIghtHawk-R7000-PS4-Nat-Type-Strict-3-Issues/td-p/1026988
That guy had to call his ISP and ended up paying for a public IP address to solve his NAT problems. You'll need to call your ISP and either ask for a public IP address, or ask them how to set up port forwarding through their gateway. Read the other thread.
TheEther
Feb 11, 2016Guru
It'll be easier to tell us whether the IP address assigned to the Internet port of your R7000 is 192.168.x.x, 10.x.x.x, or 172.16.x.x. Yes or no?
Xboxlivegamer
Feb 11, 2016Aspirant
That information is under Basic/Internet/Internet IP Address, right?
it's set to get dynamically from isp but the use static IP address is 192.168.x.x
