Xboxlivegamer
Feb 09, 2016Aspirant
NAT Issues for Xbox One Live, AC1900 Smart WiFi Router model# R7000
I'm having trouble getting open NAT for my Xbox One, it is set to moderate as of now. I've tried turning NAT filtering to open, address reservation, switching from ethernet to Wireless, port forwardi...
- Feb 11, 2016Yes, that's it. So, your ISP is NATing your traffic. Your situation is similar to the guy with WiMAX. I went and found that thread.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NIghtHawk-R7000-PS4-Nat-Type-Strict-3-Issues/td-p/1026988
That guy had to call his ISP and ended up paying for a public IP address to solve his NAT problems. You'll need to call your ISP and either ask for a public IP address, or ask them how to set up port forwarding through their gateway. Read the other thread.
Xboxlivegamer
Feb 18, 2016Aspirant
It's my ISP, I bypassed the router and I still have Moderate NAT
- JamesGLFeb 21, 2016NETGEAR Employee Retired
Hi Xboxlivegamer,
Make sure you only have one router in your network. If your modem from ISP is a modem router, you may need to set it to bridge mode and let the R7000 work as the router or set the R7000 to AP mode and the modem as the modem/router.
