Tomwillans
Dec 12, 2016Aspirant
NAT Loopback on r7000
I do not seem to be able to get NAT Loopback to work on th R7000 I have purchased precisly to enable that. Can you help. Thanks
- Retired_MemberDec 12, 2016
I don't believe stock or OEM FW supports Loopback
Try this
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
Tomwillans
Thanks for this. Just bought it specifically for the NAT Loopback. I will look at your suggestion. Do you know any routers that do?
Retired_Member
Dec 12, 2016Check ASUS
- TomwillansDec 12, 2016Aspirant
Thanks. I will seek that or then try the third party route as you suggest.
