Tomwillans
Dec 12, 2016Aspirant
NAT Loopback on r7000
I do not seem to be able to get NAT Loopback to work on th R7000 I have purchased precisly to enable that. Can you help. Thanks
- AnonymousDec 12, 2016
I don't believe stock or OEM FW supports Loopback
Try this
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
Anonymous
Dec 12, 2016I don't believe stock or OEM FW supports Loopback
Try this
Tomwillans
Dec 13, 2016Aspirant
Both port forwarding and NAT Loopback working. Managed to get it working on the Talk Talk network with TV in the UK. I have not checked out everything. The Router seems to be working well.
Thanks again.
