gvalentini
May 20, 2020Aspirant
NBN HFC BELONG NETGEAR D7000
Hi All. Yerstday night i reset my FULLY FUNCATIONAL ROUTER. The D7000. I don't remeber how i configured it. I really need help as i work from home and i don't have any mobile coverage in my are...
- May 23, 2020
Yes it worked before the router.
But no worries when i typed this i was looking through my 24tb of junk in my nas and i found that i did a full backup of the configrations.
And it worked.Thanks for your help ethier way.
Maybe people can look back at this.
michaelkenward
May 21, 2020Guru - Experienced User
gvalentini wrote:
Hi All.
Did it ever work?
gvalentini wrote:
I am with Belong. The service i have is NBN HFC.
Reading this:
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
It suggests that Hybrid Fiber-Coaxial (HFC) is not DSL. So your D7000 DSL modem/router may be connected to a modem. Guess that is your unnamed NBN box.
If so, you need to get the D7000 into router mode, bypassing the modem bit.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Look for the bit that tells you how to connect it to a cable service.
- gvalentiniMay 23, 2020Aspirant
