justkiah
Aug 15, 2019Aspirant
NBN Ready? - R8000|Nighthawk X6 AC3200 Smart WIFI Router
Hey just want to know if this router is NBN ready, they type of NBN (National Broadband Network) i have is FTTC (Fiber to the Curb) I already have my nbn modem it's a simple LAN cable you plug into t...
kholeen
Oct 18, 2019Aspirant
yes it works!
Took me a while to find all the parameters, I'm with iinet and FTTC
- in internet set up, configure PPOE and your logins from your ISP, everything else in default
+ mac spoofing if needed (plug the default modem router from your ISP, go to the Ewan settings and copy the MAC adress from the machine to your netgear MAC adress)
- In Advanced set up, go to VLAN/IPTV and enable VLAN with an ID at 2
