PMoonchild
May 06, 2022Follower
NBN SOS-ROC requirements?
Back in Feb received this message from my IP: Hello Jenny, On 31 March 2022, NBN Co is upgrading NBN FTTB/N services with a requirement for all modems to support a new stability f...
May 07, 2022Guru - Experienced User
1. what router do you have?
2. your ISP changed their requirements. Netgear didn't force them to. So if you're upset at someone, its the corporation that changed their requirements to force users to upgrade. If they forced this change on you, they should be the ones supplying you with a modem/router since they're phasing yours out. Those features require certain hardware features that have to be built into the cpu on the router. If the router doesn't have those features in hardware, no amount of firmware upgrades will fix it.
