jackbelecheur
Nov 11, 2021Follower
Neatgear nighthawk D7000 v2 drops out
Connected to australian National Broadband Network fibre 50Mbps connection. Was very stable on old ISP-supplied modem over wifi and ethernet cable (internet connection unavailable only once a month o...
michaelkenward
Nov 12, 2021Guru - Experienced User
D7000v2
What is your Internet connection technology. NBN just says "Australian Internet". And every Internet technology has "fibre" somewhere on there, often as a marketing label to make you think it is the bees knees.
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
The D7000v2 is a DSL modem/router. Do you have DSL Internet? Or are uoiu one of the many Australians who seem to have a DSL modem/router connected to a different Internet technology?
The D7000v2 can operate as a modem/router, modem only or router only.
It might help if you explained what your network looks like. What device, if any, sits between the D7000v2 and the outside word? Which socket is the Internet plugged into on the D7000v2?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
DSL Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
