asadtariq
May 21, 2022Aspirant
Need a router which has the maximum range
I am currently facing the issue of WIFI signal. We are living in a joint family in a big house where almost 12 cellphones and laptop combined connected to the same wifi. although I didn't face the sp...
asadtariq
The actual house is of 5445 sq feet but I need the router that would cover the atleast 2000sqfeet
michaelkenward
May 22, 2022Guru - Experienced User
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
- asadtariqMay 22, 2022Aspirant
Thank you for all this. I will check and hope will find a solution. Mostly I face loading issue in multiple websites and didn't know how to tackle them.
But now I guess I will get the solution.
