ScottMax
Mar 30, 2025Follower
Need acess point added to static IP setup
I have an AC2600 setup with static IP for use with a camera system that is used for live streaming. I have the system hard wired with cat 7 Ethernet cable from this router to another location withi...
Mar 31, 2025Guru - Experienced User
Are you going to be powering the AP with the POE? If so, I've got a WAX218 that works pretty rock solid over POE. While its wouldn't connect as part of a mesh, it'd still work. Or what type of AP are you looking for?
