mdjaskolka
Jan 28, 2021Aspirant
Need advice upgrading from XFi
Hello, I currently use the XFi gateway (modem) and the XFi pods. My home was built in 1860 abd the walls are brick and also lathe/plaster. WiFi has its issues even with the XFi pods. I am look...
Jan 28, 2021Guru - Experienced User
You're going to have issues with all the systems because of the plaster lathe setup.
It does a great job of blocking wifi.
And the xfi pods are actually pretty solid which pains me to say. :)
so If they're struggling to get a reasonable connection, your probably going to struggle with most systems.
If you're wanting solid/reliable connections, you'd be better to invest money into finding a way to hardwire in the access points/satellites from a mesh system.
either by having someone run ethernet, by using powerline (might be sketchy with older wiring), or using moca adapters (ethernet over coax).
- mdjaskolkaJan 28, 2021Aspirant
Thank you for the advice.
It's an option I had not considered and probably a fairly pricey one but one i have to keep in mind.
Thanks again
