Nvr2rich's avatar
Nvr2rich
Follower
Jun 20, 2022
Need best choice for router
We just moved into a rural area with no Comcast, etc. I have a modem and internet connection installed by Coastal Broadband but I need to know the best choice of a router to cover our two floor 1400 square foot home. ESVBA gave us a list of routers to buy, the list is about 5 years out of date.
Any ideas of what we should purchase? We have no coaxial cable, just an ethernet connection from the wall modem.
Thanks
LBoyes
1 Reply
  • plemans's avatar
    1400 sq ft total or per floor?
    Whats the home made from on the interior (certain materials block wifi better than others)?
    If its a standard construction, you should be fine with a single router solution, then it'd be more about what features you want.
    You can narrow the routers by filtering on the netgear router page.
    https://www.netgear.com/home/wifi/routers/
