Terapin11
Nov 24, 2020Aspirant
Need best recommendations for Nest Cams
I currently have an Orbi Mesh set up. My 5 Nest cams do not like it at all. They are constantly dropping out 100+ times a day. Nest tells me this is due to the Mesh network as the cams need to be ...
microchip8
Nov 24, 2020Master
I would go with the Qualcomm-based RAX120 router. Has slightly better range than the RAX200 and offers true hardware acceleration/offloading. Its firmware is also based on OpenWrt as opposed to the Broadcom mess in the RAX200.
Terapin11
Thank you for the quick and thoughtful response.
If I were to need a range extender to add to the RAX120, what would you recommend?
