Kallippide
Jan 02, 2022Guide
Need Extender for Net Gear Nighthawk D7000
I am looking for a Range Extender for my Night Hawk D7000. It is old, but I don't have any problems with using it in my 1200 sq ft home. However, I don't have a very good signal on my back porch if I...
- Jan 02, 2022In easy terms, it combines the router and extender SSID into one. It's great if you only need one extender. If you're needing more than 1 it's better to move to a full mesh system and not extender based one.
Jan 02, 2022Guru - Experienced User
You didn't really give us much to go off for what you need.
I'd recommend at least a dual band extender that matches your router.
You can go go netgears extenders page and sort/filter what specs you'd like or need.
Kallippide
Jan 02, 2022Guide
Thank you for your reply. I’ll follow the link to see what is compatible with my D7000.
