Kallippide
Jan 02, 2022Guide
Need Extender for Net Gear Nighthawk D7000
I am looking for a Range Extender for my Night Hawk D7000. It is old, but I don't have any problems with using it in my 1200 sq ft home. However, I don't have a very good signal on my back porch if I...
- Jan 02, 2022In easy terms, it combines the router and extender SSID into one. It's great if you only need one extender. If you're needing more than 1 it's better to move to a full mesh system and not extender based one.
Kallippide
Jan 02, 2022Guide
Thank you for your thoughts on this. I think I need to read about “mesh” now because I keep seeing that on some of the different models of extenders.
Jan 02, 2022Guru - Experienced User
- KallippideJan 02, 2022Guide
Based on what I've read so far and what you said, I only need an extender and not a mesh one. I'm neither dealing with a large square footage area nor multiple computers, TVs, etc. all running at the same time. Thank you!
- plemansJan 03, 2022Guru - Experienced User
Sounds like a good solution and wise choice to get what you need versus "the latest/greatest"
Hope it works well for you!
