Godsdemon
Dec 27, 2020Aspirant
Need help - had to use the reset button in the back
I had to use the reset button in the back last nite. Since I have done this 2 things have happened. I notice that my internet gaming seems to cycle in waves on any mmo experience that I can have ever...
Godsdemon03
Dec 28, 2020Tutor
I have tried the self update and it wouldn't update. It might be worth looking into on your end to fix. I can try to update the firmware but I'm hesitant too because I don't want to make it a paper weight if I fail.
I still need to get my armor sync'd to the other email . I don't need to pay for armor 2x
Do you have a link for the firmware?
michaelkenward
Dec 28, 2020Guru - Experienced User
Your end? I have no idea what that means.
I always update manually:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
I do it using an Ethernet connection from my PC. That is safer than relying an an automated process that might crash mid update, especially on a wifi connection.
I have already provided you with a link to the Armor section.
I tried Armor once in a beta test, but don't feel the need to pay for anything like that, so I have no idea how it works for paying customers.
- Godsdemon03Dec 28, 2020Tutor
I am hardwired. Hopefully that will help.
- GodsdemonDec 28, 2020Aspirant
Minor success! I updated the firmware- however my issue hasn't gone away. That would have been sweet if that would have fixed it. I will go thru the whole reboot sequence tomorrow and the cable company will be out on wednesday.
michaelkenward wrote:
I was referring to the router actually auto updating (thus your end to make sure it does it if you work for netgear) instead of manually doing it with the risk of making it a toaster or a very expensive paper weight.
When I read it I felt it made sense but from your perspective I wasn't descriptive enough.Your end? I have no idea what that means.
- Godsdemon03Jan 04, 2021Tutor
I did a tracert today- here is what I found:
Does this prove that the modem isn't flaking out and that its my ISP ?
This is the server I am trying to reach- I was given the other server but this was verified on the Dark Age of Camelot servers.
- GodsdemonDec 31, 2020Aspirant
No luck. ISP said they are fine coming into the house. Which makes me believe that the hard reset fried my router.
My plan is buy another and drop it in or go thru customer support.
A couple questions before I buy a new one.
Will my armor protection be able to be carried over ?
What is the cost for customer support to have them diagnose the current model?
- michaelkenwardJan 05, 2021Guru - Experienced User
Fried isn't a technical description, but it usually means permanent physical damage. As in "a lightning strike fried my modem".
A factory reset is unlikely to do that. Actually, I'd say it is impossible.
As it is, I am now getting lost in what is going on here.
You have a problem on one gaming site. What about everything else you do?
You are using Armor. Did you get your subscription fixed? What happens if you disable Armor?
None of your problems suggests an issue with your router.
