Godsdemon
Dec 27, 2020Aspirant
Need help - had to use the reset button in the back
I had to use the reset button in the back last nite. Since I have done this 2 things have happened. I notice that my internet gaming seems to cycle in waves on any mmo experience that I can have ever...
michaelkenward
Dec 28, 2020Guru - Experienced User
Godsdemon03 wrote:
I have tried the self update and it wouldn't update. It might be worth looking into on your end to fix.
Your end? I have no idea what that means.
I always update manually:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
I do it using an Ethernet connection from my PC. That is safer than relying an an automated process that might crash mid update, especially on a wifi connection.
I have already provided you with a link to the Armor section.
I tried Armor once in a beta test, but don't feel the need to pay for anything like that, so I have no idea how it works for paying customers.
Godsdemon
Dec 31, 2020Aspirant
No luck. ISP said they are fine coming into the house. Which makes me believe that the hard reset fried my router.
My plan is buy another and drop it in or go thru customer support.
A couple questions before I buy a new one.
Will my armor protection be able to be carried over ?
What is the cost for customer support to have them diagnose the current model?
- michaelkenwardJan 05, 2021Guru - Experienced User
Fried isn't a technical description, but it usually means permanent physical damage. As in "a lightning strike fried my modem".
A factory reset is unlikely to do that. Actually, I'd say it is impossible.
As it is, I am now getting lost in what is going on here.
You have a problem on one gaming site. What about everything else you do?
You are using Armor. Did you get your subscription fixed? What happens if you disable Armor?
None of your problems suggests an issue with your router.
